I am looking for a redundancy solution for my vmix system. Right now I only have one pc with vmix and one internet line.
I would like to have 2 PCs with vmix and 2 internet lines (each of the lines with different service providers).
I want to get is that if when I am live if a computer or the internet line is damaged I can continue transmitting without interruption by youtube.
Note: If you know another way to have redundancy please let me know
Thnaks
Joined: 2/9/2013(UTC) Posts: 261 Location: Katy, Texas
For internet redundancy, I use a LiveU Solo. It will bond multiple internet connections to avoid drop outs.
You can also use software Speedify
I am looking into this now as well. It is fairly straightforward to have internet redundancy, you can even route audio and video to 2 PCs. The problem I have is how do you sync the controls? This is the best article I have found on the subject. https://garethnunns.com/...ackups-and-redundancies/We need a way to select which NIC vmix uses for streaming, NDI, etc.
Joined: 1/16/2018(UTC) Posts: 28 Location: Bern, Switzerland
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: djones02 I am looking into this now as well. It is fairly straightforward to have internet redundancy, you can even route audio and video to 2 PCs. The problem I have is how do you sync the controls? This is the best article I have found on the subject. https://garethnunns.com/...ackups-and-redundancies/We need a way to select which NIC vmix uses for streaming, NDI, etc. This article is indeed very good and covers all aspects you should think off. I'd only add that after using speedify for years we've switched over to a peplink hardware bonder and are not looking back - less it stuff to care about and dead solid whilst not too expensive to buy and keep running.
Originally Posted by: hidavid Originally Posted by: djones02 I am looking into this now as well. It is fairly straightforward to have internet redundancy, you can even route audio and video to 2 PCs. The problem I have is how do you sync the controls? This is the best article I have found on the subject. https://garethnunns.com/...ackups-and-redundancies/We need a way to select which NIC vmix uses for streaming, NDI, etc. This article is indeed very good and covers all aspects you should think off. I'd only add that after using speedify for years we've switched over to a peplink hardware bonder and are not looking back - less it stuff to care about and dead solid whilst not too expensive to buy and keep running. hidavid, which peplink product are you using? Balance 20X? MAX HD2? and are you also using Speedfusion in the cloud? We are primarily looking at a rock solid vMixCall connectivity. We are using speedify, but everytime we have call issues we do not know if its speedify or my ISP or network.. Any help is appreciated!!! Rgds Supreet
