Salvador
#1 Posted : Wednesday, December 28, 2022 3:06:38 AM(UTC)
Salvador
Dominican Republic
I am looking for a redundancy solution for my vmix system. Right now I only have one pc with vmix and one internet line.
I would like to have 2 PCs with vmix and 2 internet lines (each of the lines with different service providers).
I want to get is that if when I am live if a computer or the internet line is damaged I can continue transmitting without interruption by youtube.
Note: If you know another way to have redundancy please let me know
Thnaks
Kelvin
#2 Posted : Wednesday, December 28, 2022 3:49:32 AM(UTC)
Kelvin
For internet redundancy, I use a LiveU Solo. It will bond multiple internet connections to avoid drop outs.
Pavel
#3 Posted : Wednesday, January 18, 2023 1:10:38 AM(UTC)
Pavel
You can also use software Speedify
djones02
#4 Posted : Wednesday, May 17, 2023 4:18:18 AM(UTC)
djones02
Canada
I am looking into this now as well.
It is fairly straightforward to have internet redundancy, you can even route audio and video to 2 PCs.
The problem I have is how do you sync the controls?
This is the best article I have found on the subject.
https://garethnunns.com/...ackups-and-redundancies/
We need a way to select which NIC vmix uses for streaming, NDI, etc.
hidavid
#5 Posted : Thursday, June 22, 2023 12:33:14 AM(UTC)
hidavid
This article is indeed very good and covers all aspects you should think off.
I'd only add that after using speedify for years we've switched over to a peplink hardware bonder and are not looking back - less it stuff to care about and dead solid whilst not too expensive to buy and keep running.
duxmedia
#6 Posted : Sunday, July 16, 2023 2:47:51 AM(UTC)
duxmedia
hidavid, which peplink product are you using? Balance 20X? MAX HD2? and are you also using Speedfusion in the cloud? We are primarily looking at a rock solid vMixCall connectivity. We are using speedify, but everytime we have call issues we do not know if its speedify or my ISP or network.. Any help is appreciated!!!
Rgds
Supreet
