Shortcut to set Input Search string?
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
You can use a shortcut to set SelectCategory = Search, with the search string being whatever was last typed in.
Is there a way to set the search string via shortcut?
(Custom categories handle some of this, but each input can only be assigned to a single category. But one can add text to Virtual Inputs. For instance V1: podium #scene1 #scene3 V2: table #scene2 V3: backwall #scene3
then searching for "#scene3" shows V1 and V2, etc.
Originally Posted by: FoolOnTheHill  Is there a way to set the search string via shortcut?
no or Ctrl-V
Thanks.
If I could, via shortcut, get to the point where Ctl-V would work, that would be fine. I can't activate the search input string box (for ctl-v or anything) via function/shortcut.
