Feature Requests
Virtual Set Modification/Improvement
Hello, Well done for a good job on vMix... The above subject matter refers. I know this is too late for vMix 13 but will it be possible to have a look at re-modifying the Virtual Set to look like the image below for maybe vMix 14? Why the above?I am currently experimenting with a 3 camera angles and realized that using 3 cameras with 3 same virtual sets but different angles assigned to each camera will take a bit of spaces... I am now wondering if it will be possible to remove the preview window for virtual sets to create space, like the diagram above but have the active window stroked in RED or whatever good colour as indicated also in the above diagram. By so doing, we can have all angles (Left Cam, Center Cam, and Right Cam) well/properly set, based on the Virtual Sets, to give it a good real feel of look like the diagram below:  - Rottimmy vMix Evangelist
Joined: 11/14/2012(UTC) Posts: 416  Location: Finland Thanks: 274 times Was thanked: 40 time(s) in 38 post(s)
Damn2Good4U wrote:Hello, Well done for a good job on vMix... The above subject matter refers. I know this is too late for vMix 13 but will it be possible to have a look at re-modifying the Virtual Set to look like the image below for maybe vMix 14? Why the above?I am currently experimenting with a 3 camera angles and realized that using 3 cameras with 3 same virtual sets but different angles assigned to each camera will take a bit of spaces... I am now wondering if it will be possible to remove the preview window for virtual sets to create space, like the diagram above but have the active window stroked in RED or whatever good colour as indicated also in the above diagram. By so doing, we can have all angles (Left Cam, Center Cam, and Right Cam) well/properly set, based on the Virtual Sets, to give it a good real feel of look like the diagram below:  - Rottimmy vMix Evangelist +1 Asked this active retangle for Vitual Sets a long time ago, but not yet in v13. Kind regards, Jan
Feature Requests
