Youtube Login security error
Hi.
I know this has been asked several times before, but I can't find the answer. Due to security restrictions last year, Google doesn't allow to sign in just with the previous user and pass. Right now it will reject the login saying this browser isn't secure. Is there any way to solve this? Capturing a youtube channel via desktop will not capture the audio, btw.
Thanks :=) But... I think I may have explained myself a little badly. The browser is the Vmix browser, not the external one. That's the point. The Input called Browser (Vmix native) is not compatible anymore with the new Google security regulations. So, it's up to Vmix to update the browser (chromium based, I guess). As far as I know, the only way to capture a browser with audio is thru NDI (which is what I've done).
Regards
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
Actually vMix uses Google Chrome as its browser. And it uses your install of Chrome!
To update Chrome, start the application, click the trio of dots in the top right corner, select HELP, select About Google Chrome. That will initiate the update process.
Did that work for you?
- Tom
Originally Posted by: knob2001  Thanks :=) But... I think I may have explained myself a little badly. The browser is the Vmix browser, not the external one. That's the point. The Input called Browser (Vmix native) is not compatible anymore with the new Google security regulations. So, it's up to Vmix to update the browser (chromium based, I guess). As far as I know, the only way to capture a browser with audio is thru NDI (which is what I've done).
Regards Hello. Not only ndi. For audio from browser you can install Virtual audio cables. See this video for example on how to do this For apps like browser that you cant select the audio device, simply go to windows audio speaker icon in taskbar and select a line virtual as output.Then Vmix-->Add input-->Audio input-->same virtual line and ready.
