benwick
#1 Posted : Friday, May 5, 2023 5:43:25 AM(UTC)
benwick
We have a 4 camera replay set up, all at 1080p 50, and the replays quite often start to jump on our rig.
Specs:
12th Gen Intel® Core™ i7-12700 (25 MB cache, 12 cores, 20 threads, 2.10 GHz to 4.90 GHz Turbo)
32 GB, 2 x 16 GB, DDR5, 4400 MHz
NVIDIA® GeForce RTX™ 3070, 8 GB GDDR6, LHR
1TB M.2 PCIe NVMe SSD
I since bought a WD_Black SN750 4TB SSD just for replays thinking this would fix the issue, but it still persists.
Any fixes or workarounds would be great. I read another post about potentially turning off recording whilst we play a replay. This isn't ideal, but would be a better solution if I could get some advice on how to implement this?
Thanks.
live
#2 Posted : Tuesday, May 23, 2023 5:30:02 PM(UTC)
live
Following, having the same issue.
#3 Posted : Tuesday, May 23, 2023 8:08:04 PM(UTC)
@ benwick
I suspect that your CPU is too slow and does not meet the minimum system specs for vMix 4 camera Instant Replay:
https://www.vmix.com/hel.../SystemRequirements.html
It is the major reason why laptops are not recommended for use with vMix Instant Replay.
SportsNetUSA.net
#4 Posted : Saturday, May 27, 2023 1:07:16 PM(UTC)
SportsNetUSA.net
@benwick
This is a desktop rig, correct? If so what happens when you limit Instant Replay to only 2 cameras? Same problem?
Perhaps there is an issue with the Intel UHD Graphics 770 built into the CPU.
statman24
#5 Posted : Tuesday, June 13, 2023 7:53:36 AM(UTC)
statman24
Same issue here.
I have recreated this with a single NDI camera. Sometimes it stops, starts, stops, starts. Sometimes it goes fine.. then speeds up at the end.
Asus Rog G17 with AMD Ryzen 9 and Nvidia 3060 GPU
mpvmix
#6 Posted : Monday, July 31, 2023 9:34:10 PM(UTC)
mpvmix
Same problem over here when the inputs of the Instant Replay are SRT and having all the specs required.
live
#7 Posted : Friday, August 18, 2023 5:07:05 PM(UTC)
live
I have found an issue where Windows defender is scanning the USB ports for virus' and slows the band width down to a crawl. This may be the same for LAN but I am not sure. My tech told me to download malware bytes and use the free version and this will uninstall defender. In testing it has made a huge difference. I will try it in production tomorrow and get back with the results. 90% Better in production.
