kinpari
#1 Posted : Sunday, May 7, 2023 9:23:24 PM(UTC)
kinpari
Congo, The DRC
I am looking to buy an SDI output card for Vmix, on a budget .. https://www.amazon.fr/gp...A1S3ENL13XN9YF&psc=1
The goal is to broadcast in SD, to a DVBT2 encoder.
Is the Blackmagic Design DeckLink Mini Monitor 4K Black compatible with Vmix for output ?
Thanks in advance,
best Regards
#2 Posted : Sunday, May 7, 2023 11:25:24 PM(UTC)
@ kinpari
Yes, the Decklink Mini Monitor 4K is supported by vMix:
https://www.vmix.com/sof...are.aspx#capturehardware
The real question is whether or not you have an available PCIe slot to plug it into as explained in these videos:
kinpari on 5/8/2023(UTC)
kinpari
#3 Posted : Monday, May 8, 2023 1:56:34 AM(UTC)
kinpari
Congo, The DRC
Thank you very much for your answer,
I am looking forward for the PCIe Slot
