Split vMix on Multiple monitors
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi all, would anyone know how to split the vMix app on multiple screens, for example I'm trying to figure out how to just see the preview and output on one monitor, and the inputs and audio on another?
Thanks in advance.
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
A little bit can be done with the multiview. You can customize as well. The other option is to create a layered shot with the layout you wanna have and enable NDI for it. With a computer or decoder you could display that on a display with delay. All this is more or less only for inputs you have, not the interface itself unless you add a screengrab as a source, which would lead to some reflections, or use a seperate software for that.
 1 user thanked mavik for this useful post.
