vadimtv
#1 Posted : Thursday, April 20, 2023 5:05:23 PM(UTC)
vadimtv
Russian Federation
Good afternoon . How can I make a {m:ss} format countdown timer for MMA fights bye. In battles, the chronometer starts at 5.00 and then descends 4:59 4:58...... 0:00 ?
#2 Posted : Thursday, April 20, 2023 5:38:37 PM(UTC)
Was thanked: 1011 time(s) in 832 post(s)
One can add the format to the vMix user.config file to create the extra option
nikosman88 on 4/21/2023(UTC)
richardgatarski
#3 Posted : Friday, April 21, 2023 4:07:59 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
Yeah! But that means it will only be available on that particular PC for that Windows user. Or. am I wrong about that?
Would it not be better to Export the Settings to a file (.config) and add the desired format. Which, in vadimtv's case would result in something like
Code:
           <setting name="CountdownFormats" serializeAs="Xml">
                <value>
                    <ArrayOfString xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                        xmlns:xsd="http://www.w3.org/2001/XMLSchema">
                        <string>HH:mm:ss</string>
                        <string>mm:ss</string>
                        <string>m:ss</string>
                        <string>ss</string>
                        <string>HH</string>
                        <string>mm</string>
                    </ArrayOfString>
                </value>
            </setting>
#4 Posted : Friday, April 21, 2023 5:02:06 AM(UTC)
Available in current instalation
in vMix64.exe.config before installing vMix (and changing file acces/edit permission)
In user.config after installing vMix (more practical for additional changes)
Either way will have to make the change with each download or update
