Good afternoon . How can I make a {m:ss} format countdown timer for MMA fights bye. In battles, the chronometer starts at 5.00 and then descends 4:59 4:58...... 0:00 ?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: vadimtv  Good afternoon . How can I make a {m:ss} format countdown timer for MMA fights bye. In battles, the chronometer starts at 5.00 and then descends 4:59 4:58...... 0:00 ? One can add the format to the vMix user.config file to create the extra option
Originally Posted by: doggy  One can add the format to the vMix user.config file to create the extra option Yeah! But that means it will only be available on that particular PC for that Windows user. Or. am I wrong about that? Would it not be better to Export the Settings to a file (.config) and add the desired format. Which, in vadimtv's case would result in something like Code: <setting name="CountdownFormats" serializeAs="Xml">
<value>
<ArrayOfString xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<string>HH:mm:ss</string>
<string>mm:ss</string>
<string>m:ss</string>
<string>ss</string>
<string>HH</string>
<string>mm</string>
</ArrayOfString>
</value>
</setting>
Originally Posted by: richardgatarski  Yeah! But that means it will only be available on that particular PC for that Windows user. Or. am I wrong about that?
Available in current instalation in vMix64.exe.config before installing vMix (and changing file acces/edit permission) In user.config after installing vMix (more practical for additional changes) Either way will have to make the change with each download or update
