SnipeeFTW
#1 Posted : Friday, March 24, 2023 6:47:09 AM(UTC)
SnipeeFTW
India
I have 3 pc for Game Streaming i have one 3060 Gpu pc for Main production, Two 1660 Gpu Pc for Spectating and NDI Output, I will Collect Data from Two Spectating Pc to Main production PC through NDI Screen Capture or Screen Capture HX,
But My Problem is When i am Conneting Two Spectate pc in NDI Screen Capture its Getting Lagging in one Feed, If i Connect one pc on NDI Screen Capture and Another One in NDI Screen Capture HX i works Fine. I need Sollution for This,
How can i Use only one Capture? Either Screen capture or Screen Capture HX?
I have TPLINK TL-SG108E 1Gigabyte Swtich, My lan cable was Cat 6A, All Connected in Same network,
But still i have this Problm Kindly help me about this,
one more Doubt is there any ip setting for PC.
hilton.moraes
#2 Posted : Tuesday, April 18, 2023 5:34:29 AM(UTC)
hilton.moraes
Brazil
I'm having the same delay problem between images from 7 Sony SRG-X400 cameras that generate NDI stream. When I use up to 3 cameras there is no delay, when I use 4 or more cameras I start to have a delay problem between them. Were you able to solve the problem?
mavik
#3 Posted : Thursday, April 20, 2023 11:54:03 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Have you tried vMix Desktop Capture instead of the NDI tools already?
nikosman88
#4 Posted : Friday, April 21, 2023 4:01:32 AM(UTC)
nikosman88
Greece
Hello. When the problem starts to appear, have you checked your network if it goes to it`s limits? Or if in vmix RenderTime goes too high. These 2 things can make your ndi stream to lag
mavik
#5 Posted : Tuesday, April 25, 2023 1:16:19 AM(UTC)
mavik
If a few NDI sources work and the more you add the more laggy it gets it's definitely a sign of a network overload. I made a clip to demonstrate how quickly even with a few source the network can be saturated.
Hope that helps.
