msanthababu
#1 Posted : Tuesday, April 4, 2023 7:18:57 PM(UTC)
msanthababu
India
hi Every One
I like vMix Software , I decided to Make my Own Scheduling APP for Vmix
pls Download and Try this Software
vTIMER2023.rar (289kb) downloaded 87 time(s).
pls reply for any Bugs
This is so simple , Light and Easy to Use .
if you want schedule a Program just rename the Input name In vmix. as time or Date and Time
If you want to Schedule a Program to Fixed date and Time just Add Input as List and Rename with time/date(Ex.14:00:00/2023-04-04) 24 Hours Format
If you want to Schedule Daily Program like Break ads. Just take a List input and Rename(ex14:00:00) its plays Daily
for Gap filling use a Trigger ( OnComplition Trigger with Filler Input )
for ads pls use a trigger to preview.
I uploaded few Screen Shots for Better Understanding.
I will Give More Features On Next Update
Sorry for the Poor English
Thank You.
nikosman88
#2 Posted : Tuesday, April 4, 2023 10:17:55 PM(UTC)
nikosman88
Greece
Was thanked: 96 time(s) in 92 post(s)
Hello. I tried to run the program but it was blocked from windows defender!! It said that it has a trojan that called wacatac.B.ml...
thanks 1 user thanked nikosman88 for this useful post.
Chircanu on 4/5/2023(UTC)
msanthababu
#3 Posted : Tuesday, April 4, 2023 11:41:58 PM(UTC)
msanthababu
India
I will check tq.i didn't have any problem.
nikosman88
#4 Posted : Thursday, April 6, 2023 12:48:19 AM(UTC)
nikosman88
Greece
Hello i tried to open the program in my old laptop with also windows 10 (without connection to internet just to be sure and then i formated it) and no message comes up. My opinion for your program is that in this stage is very poor. Personally i need something like this https://forums.vmix.com/...ler---vMixScheduler-Fork that it has a way to program multiple events and know what time every event ends and you make 24-hour workflow very easy. For better improving your program i personally suggest to do this something like this. For my needs the only improvement that vMixScheduler needs is a way to play directly lists from vmix. Your program adds this feature but misses all the others.
msanthababu
#5 Posted : Monday, April 10, 2023 11:57:00 PM(UTC)
msanthababu
India
THANKS FOR YOUR TRY, SURE I WILL ADD MORE FUNCTION LIKE YOU, IN SIMPLE WAY, WITH SINGLE UI.
thanks 1 user thanked msanthababu for this useful post.
nikosman88 on 4/11/2023(UTC)
