Joined: 1/19/2021(UTC) Posts: 10  Location: RAJAHMUNDRY Thanks: 2 times Was thanked: 5 time(s) in 4 post(s)
hi Every One I like vMix Software , I decided to Make my Own Scheduling APP for Vmix pls Download and Try this Software  vTIMER2023.rar (289kb) downloaded 90 time(s).pls reply for any Bugs This is so simple , Light and Easy to Use . if you want schedule a Program just rename the Input name In vmix. as time or Date and Time If you want to Schedule a Program to Fixed date and Time just Add Input as List and Rename with time/date (Ex.14:00:00/2023-04-04) 24 Hours Format If you want to Schedule Daily Program like Break ads. Just take a List input and Rename (ex14:00:00) its plays Daily for Gap filling use a Trigger ( OnComplition Trigger with Filler Input ) for ads pls use a trigger to preview. I uploaded few Screen Shots for Better Understanding.I will Give More Features On Next Update Sorry for the Poor English Thank You.
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 96 time(s) in 92 post(s)
Hello. I tried to run the program but it was blocked from windows defender!! It said that it has a trojan that called wacatac.B.ml...
 1 user thanked nikosman88 for this useful post.
I will check tq.i didn't have any problem.
Hello i tried to open the program in my old laptop with also windows 10 (without connection to internet just to be sure and then i formated it) and no message comes up. My opinion for your program is that in this stage is very poor. Personally i need something like this https://forums.vmix.com/...ler---vMixScheduler-Fork that it has a way to program multiple events and know what time every event ends and you make 24-hour workflow very easy. For better improving your program i personally suggest to do this something like this. For my needs the only improvement that vMixScheduler needs is a way to play directly lists from vmix. Your program adds this feature but misses all the others.
THANKS FOR YOUR TRY, SURE I WILL ADD MORE FUNCTION LIKE YOU, IN SIMPLE WAY, WITH SINGLE UI.
 1 user thanked msanthababu for this useful post.
