Feature Requests
Shortcuts to move and crop input Position +1 /-1 pixel
Thanks: 192 times Was thanked: 20 time(s) in 17 post(s)
Suggestion is to have a shortcut function for:
Input, Position: X Y Z crop X1 Y1 X2 Y2
The shortcut would have a configurable value, i.e. +1 will move (x, Y) 1 pixel to the right; -1 will move it one pixel to the left. When a button is assigned to this shortcut, pressing it 3 times will move the input 3 pixel on the canvas, starting at its initial position.
Use case: we use a scoreboard camera which we clone into virtual inputs. The camera sometimes is moved in between events and we position and crop the virtual inputs before each event.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
and here I am - one year later - not exactly a rookie using vMix, being surprised not to find these shortcuts already.
Absolutely a +1 from me.
(I think basically all functions should have a shortcut, and many should have a toggle as well)
 1 user thanked Amokka for this useful post.
Hi Amokka, kind thanks for the support. I'm glad you share the same view. vMix has many shortcuts but there seems to be no overall plan, that makes sure they cover all functions. Hopefully, your support helps stipulate this need once more.
Greetings from Arie
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Ario  Hi Amokka, kind thanks for the support. I'm glad you share the same view. vMix has many shortcuts but there seems to be no overall plan, that makes sure they cover all functions. Hopefully, your support helps stipulate this need once more.
Greetings from Arie One can allready pan and zoom per pixel with a shortcut. Also using a mouse scroll wheel with cursor over the position slider lets you change positions/values per pixel Maybe should change the feature request to add shortcut for cropping too maybe
Joined: 4/5/2023(UTC) Posts: 1  Location: Stockholm Was thanked: 1 time(s) in 1 post(s)
Being able to change crop for an input and/or layer from the API would be great. Moving from Atem mixers to vmix, that is one of the features I miss the most.
 1 user thanked thezulk for this useful post.
Feature Requests
