dbroo
#1 Posted : Tuesday, April 4, 2023 8:01:26 AM(UTC)
dbroo
I'm using vMix to feed Microsoft teams for a presentation. While the feed seems to work great with both the video and my microphone, for some reason I can't get the sound from a video clip to play. The master audio shows both microphone and video clip are feeding through just fine. But for some reason, while I can be heard just fine the video clip can't be heard. It doesn't make sense if the master is showing the audio is present. Incidentally, I haven't hard this problem in Zoom.
mavik
#2 Posted : Tuesday, April 4, 2023 7:58:43 PM(UTC)
mavik
This is the teams sound cancel issue. Go to settings and select no sound canceling in the meeting. Then you will have sound.
dbroo
#3 Posted : Wednesday, April 5, 2023 7:55:46 AM(UTC)
dbroo
I couldn't find that setting in Teams. Interestingly, I'm having the same problem in Zoom. Seems more likely that it's a problem with what I'm feeding. I could understand it being muted for me, but not for the others in the meeting.
mavik
#4 Posted : Thursday, April 6, 2023 2:26:00 AM(UTC)
mavik
dbroo
#5 Posted : Thursday, April 6, 2023 6:53:54 AM(UTC)
dbroo
Turns out it was a vMix issue. I simply had to go into the settings for audio input and create an A and B output assigning A to microphone and B to the computer output. Once I did that, I could hear the audio from the video clip just fine.
