Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi all
i have a problem and i dont know you to do
SO i have severals multiview and i have a Vmixcall i make the correct trigger on my vmixcall (working great when i switch on it)
My problem is in the multiview sometines the vmix call can input in a layer soemtine not so the trigger on my vmixcall input doesnt work when the call is in the multiview?
i try to put tranistion in and overlay in same thing
how i can to do please?
Thanks so much
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
From the help files: Quote:Triggers and MultiView Overlays
Triggers will only be activated on the primary input. For example if Input A is setup with Input B and C as MultiView Overlays, only the Input A trigger will be used. The exception to this is OnCountdownCompleted which will trigger regardless. https://www.vmix.com/help26/Triggers.html
I know trigger but my problem is the trigger who are in my vmixcall. when i put the input(multiview)(track2) in program (multiview is a made with a video for example (1) and a vmixcall(4)) the trigger who are in vmixcall(4) dont work/start  cac2.PNG (10kb) downloaded 0 time(s). call.PNG (30kb) downloaded 0 time(s).
Have you even read what I quoted?
Triggers of layered inputs are not executed. You'd have to copy them to input 2 to work.
Another solution could be found in scripting. Or getting creative with adding layers on top of the call input.
 1 user thanked dmwkr for this useful post.
Yes i see and try this before and working great But the problem is in the multiview layer (where is the call is) isnot always the call it will be another input and making these triggers in the input 2 (multiview) make me have the sound ... trigger . from the Call and i dont want it when the layer x is not the call in it
I dont know if you understand what i mean
Yes, I do understand.
Possible solutions include: - Scripting - Creative use of layers: Creating a virtual Input of your call and placing it with the other contents of your multiview on top of your call, thus using the original triggers. - Dynamic Inputs: Setting your call to a dynamic input and using the triggers in your mulltiview on the Dynamic Input.
