davidcl
#1 Posted : Saturday, April 1, 2023 4:21:00 PM(UTC)
davidcl
Gabon
Hi all
i have a problem and i dont know you to do
SO i have severals multiview and i have a Vmixcall
i make the correct trigger on my vmixcall (working great when i switch on it)
My problem is in the multiview sometines the vmix call can input in a layer soemtine not
so
the trigger on my vmixcall input doesnt work when the call is in the multiview?
i try to put tranistion in and overlay in same thing
how i can to do please?
Thanks so much
dmwkr
#2 Posted : Saturday, April 1, 2023 7:10:47 PM(UTC)
dmwkr
From the help files:
Triggers and MultiView Overlays
Triggers will only be activated on the primary input. For example if Input A is setup with Input B and C as MultiView Overlays, only the Input A trigger will be used.
The exception to this is OnCountdownCompleted which will trigger regardless.
https://www.vmix.com/help26/Triggers.html
davidcl
#3 Posted : Saturday, April 1, 2023 8:12:29 PM(UTC)
davidcl
Gabon
I know trigger
but my problem is the trigger who are in my vmixcall.
when i put the input(multiview)(track2) in program (multiview is a made with a video for example (1) and a vmixcall(4)) the trigger who are in vmixcall(4) dont work/start
dmwkr
#4 Posted : Saturday, April 1, 2023 8:50:23 PM(UTC)
dmwkr
Have you even read what I quoted?
Triggers of layered inputs are not executed. You'd have to copy them to input 2 to work.
Another solution could be found in scripting. Or getting creative with adding layers on top of the call input.
thanks 1 user thanked dmwkr for this useful post.
doggy on 4/1/2023(UTC)
davidcl
#5 Posted : Saturday, April 1, 2023 9:10:28 PM(UTC)
davidcl
Gabon
Yes i see and try this before and working great
But the problem is in the multiview layer (where is the call is) isnot always the call it will be another input
and making these triggers in the input 2 (multiview) make me have the sound ... trigger . from the Call and i dont want it when the layer x is not the call in it
I dont know if you understand what i mean
dmwkr
#6 Posted : Monday, April 3, 2023 6:24:19 PM(UTC)
dmwkr
Yes, I do understand.
Possible solutions include:
- Scripting
- Creative use of layers: Creating a virtual Input of your call and placing it with the other contents of your multiview on top of your call, thus using the original triggers.
- Dynamic Inputs: Setting your call to a dynamic input and using the triggers in your mulltiview on the Dynamic Input.
