Vardian
#1 Posted : Thursday, March 30, 2023 2:46:43 AM(UTC)
Vardian
As you can see below, we are getting a clear picture when we use our camera's software, but in Vmix it is pixelated and green. Updated to the latest Vmix version but no change. We had no problems for about two years until the last several months. Any thoughts?
Here's what we are working with:
Graphics card: NVIDIA GeForce GTX 1650
Vmix: 26.0.0.40
Camera running into Intensity Pro 4K
1920x1080
NTSC 60p
YUY2
Using AW-HN38 Panasonic camera
Computer:
Device name DESKTOP
Processor Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz 3.00 GHz
Installed RAM 16.0 GB (15.8 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 11 Home
Version 22H2
Installed on ‎3/‎21/‎2023
OS build 22621.1413
Experience Windows Feature Experience Pack 1000.22639.1000.0
Screenshot 2023-03-29 124556.png (1,291kb) downloaded 3 time(s).
mavik
#2 Posted : Thursday, March 30, 2023 3:00:53 PM(UTC)
mavik
I would try to find the difference. How do you capture both. Make everything matching each other. HDMI vs. SDI. Stream vs. cable. vMix is usually nutreal and does not change the image.
The images is different so there must be a difference. Exclude things from the chain, check and compare settings. The usual debugging aproaches.
Vardian on 3/30/2023(UTC)
Vardian
#3 Posted : Thursday, March 30, 2023 11:36:18 PM(UTC)
Vardian
I guess I am mostly concerned with the pixelation of the vmix picture not so much the difference (I wanted to show that it wasn't a problem with the camera itself). We plan on replacing the HDMI cord to see if that does anything. After that we suspect its the Infinity Pro 4k (unless there are setting issues I should be aware of)
mavik
#4 Posted : Friday, March 31, 2023 12:42:45 AM(UTC)
mavik
For BMD please update drivers to the latest and check within there desktop software if you see the same pixelated image. If so, it's a setting of the card itself. Make sure the settings match. If the cam output is 1080 with 30 frames make sure to capture exactly 1080 with 30 frames.
Da1DaOnly1
#5 Posted : Sunday, February 9, 2025 2:45:01 AM(UTC)
Da1DaOnly1
I am having a pixelation issue with one of my cameras after I moved it from 1 location to another.
That camera has been working fine for the past 3 years until now. Nothing has changed except it's location. I had this same issue at another church & could not figure it out. It finally resolved itself at that church.
The camera is a Marshall CV630-IP.
Here are my PC settings:
Device name DESKTOP-05SKGKE
Processor AMD Ryzen 7 5700X 8-Core Processor 3.40 GHz
Device ID 7AD1CB3E-3165-4B04-92E6-D69DFFACE4D6
Product ID 00342-20935-28858-AAOEM
Vmix v. 27.0.0.91 Screenshot 2025-02-08 112245.png (1,397kb) downloaded 2 time(s).
