I have some trouble with my streaming setup. So basically I stream car racing video games. I have a few overlays that display informations about the game. I would like to sum up all those info into an Excel file, and then use the vMix UTC to select the appropriate info.
So far, I managed to put the Excel file into vMix on the Data Sources.
On the vMix UTC, I managed to put a button to select the next row of data, it works well. But I would like to have an actual clickable list to choose from.
For example, I have a car info overlay, I want to be able to have a list in vMix UTC with all the car models, and I just click on which ever car is on the screen right now. I do realize I can create lists manually, but I would like the list to be liked to the excel file, because there is a lot of data to enter. Also, I would like the list in vMix UTC to automatically update when the info is changed in the Excel file.
Is this possible at all ?
Thank you very much !
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
What is wrong with clicking on a row of the (open) datasource window ?
What is wrong with clicking on a row of the (open) datasource window ? I installed the vMix UTC on an other computer, so it would be operated by someone else (and not from the vMix computer).
Originally Posted by: Pumpkin  Originally Posted by: doggy  Originally Posted by: Pumpkin  Hello,
What is wrong with clicking on a row of the (open) datasource window ? I installed the vMix UTC on an other computer, so it would be operated by someone else (and not from the vMix computer). OK makes sense We create/use small custom userfriendly apps (.net) to have a display of a selectable datasource sending the info through httprequests to the production machine
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
To make it work in UTC, you would have to add the Excel file as External Data in UTC itself and use it as a Data Source on a List widget.
 1 user thanked dmwkr for this useful post.
Originally Posted by: dmwkr  To make it work in UTC, you would have to add the Excel file as External Data in UTC itself and use it as a Data Source on a List widget. Thanks ! So I've done that, it works ! But, when I modify the Excel document and save it, UTC crashes and I have to re-open it. So yeah, I have to be careful of that if I need to change the information during the stream. Also, the Excel widget in UTC doesn't seem to support different sheets on the same Excel file ? It just loads the first one. So I would have to make new Excel files with each sheet of info. EDIT : Oh actually I saw that you can choose the sheet with the "Sheet number" thing, so it's perfect ! Thank again !
Originally Posted by: doggy  Originally Posted by: Pumpkin  Originally Posted by: doggy  Originally Posted by: Pumpkin  Hello,
What is wrong with clicking on a row of the (open) datasource window ? I installed the vMix UTC on an other computer, so it would be operated by someone else (and not from the vMix computer). OK makes sense We create/use small custom userfriendly apps (.net) to have a display of a selectable datasource sending the info through httprequests to the production machine I see, do you have some examples of the apps you use ?
Originally Posted by: Pumpkin  I see, do you have some examples of the apps you use ?
sorry not really (privacy) But the basic is simple; creating window form (vb.net for example) that contains Datagridviews of your datasource responding to a roww selection sending that data to a vmix title Google for vb.net and datagridview for simple examples
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
 1 user thanked JAIRODJ for this useful post.
Originally Posted by: doggy  Originally Posted by: Pumpkin  I see, do you have some examples of the apps you use ?
sorry not really (privacy) But the basic is simple; creating window form (vb.net for example) that contains Datagridviews of your datasource responding to a roww selection sending that data to a vmix title Google for vb.net and datagridview for simple examples Noted, thank you very much!
