Systems
4k station inputs pcie lanes limitations
Joined: 11/23/2022(UTC) Posts: 2  Location: Luxembourg
I'm building a station with these components:
Intel Core i9-12900KF (3.2 GHz / 5.2 GHz) nVidia 3090 FE be quiet! Silent Loop 2 360mm Gigabyte Z690 AORUS Tachyon Corsair Vengeance DDR5 32 Go (2 x 16 Go) 5200 MHz CL40 - Noir Samsung SSD 980 PRO M.2 PCIe NVMe 2 To be quiet! Silent Base 802 (Noir) be quiet! Straight Power 11 850W 80PLUS Platinum
I have a question concerning the pcie lanes, The cpu has 20 of it so: 4 for the nvme drive, 8 for gpu(enough no need to use 16) and 8 for a Decklink 8k Pro. The initial plan was to have 4 physical 4k inputs and switch between the decklink and a elgato camlink pro (4HDMI) depending of the production. But I saw that the elgato uses only 4 pcie lanes.
So my question is: if I mount my nvme drive on the chipset lanes to gain 4 lanes, and mount both Elgato and BM capture cards, will I be able to use it at the same time? I'm only talking about the pcie limitations, maybe 8 4k inputs will be too much for the machine but could 6 4k or 8 HD work like this?
Thank you in advance
If you want 4 4k60 inputs have you looked at the Decklink Quad HDMI?
Also note the Camlink Pro is 4k30 and not 4k60 if that matters to you.
Joined: 10/20/2023(UTC) Posts: 162  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
CPU = 20 LANES PCIE 1 = 5.0 x8 = nVidia 3090FE PCIE 2 = 5.0 x8 = DECKLINK 8K pro M2.1 = PCIE 4.0 x4 chipset Z690 = 4.0 x8 elgato cam link pro = 2.0 x4 also it's ok but not recommended by Vmix Regarding your setup idea: You need to test whether it's better to put the Windows SSD on the M2_1 port (CPU) + elgato cam link pro on pcie slot 4 (chipset Z690) or ssd windows on the M2_2 port (chipset) and elgato cam link pro on M2_1 port (CPU) Perhaps a solution for 8 inputs 4K30p on the PCIe CPU lanes: Install an M.2 controller card (PCIe 5.0 x8 to 2 M.2 ports) and enable x4+x4 bifurcation in the BIOS. Connect M.2 to PCIe x4 risers to the ports on the M.2 controller card. And connect two Elgato CamLink Pro cards to the M.2/PCIe x4 risers. Given the size of the 3090 FE, the Elgato cards need to be relocated.  schema 2 x cam link pro.png (573kb) downloaded 15 time(s).
Systems
