How to zoom-in a video input.
I have a question. I need to do a digital zoom-in of an open plane. I want to do it with VMIX. Select that camera input and have it zoom-in digitally as if you were using a video camera. Thank you.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: jaialai  I have a question. I need to do a digital zoom-in of an open plane. I want to do it with VMIX. Select that camera input and have it zoom-in digitally as if you were using a video camera. Thank you. check the help files ( vMix documentation)!! it's worth a read! Input settings -> Position -> zoom or PTZ - Pan Tilt Zoom
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
You can also do this with the Zoom feature of Virtual Sets See 5:25
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Ohh, I believe what you men is how to have a zoom happening live. Add the input as usual, right click on the small cog buttom right of that input and select "create virual input". Open the virtual input and change the zoom/position whatever. Merge between the two.
