jaialai
#1 Posted : Tuesday, February 21, 2023 5:39:08 AM(UTC)
jaialai
I have a question. I need to do a digital zoom-in of an open plane. I want to do it with VMIX. Select that camera input and have it zoom-in digitally as if you were using a video camera.
Thank you.
#2 Posted : Tuesday, February 21, 2023 6:02:33 AM(UTC)
Thank you.
check the help files ( vMix documentation)!! it's worth a read!
Input settings -> Position -> zoom
or
PTZ - Pan Tilt Zoom
Salvatore
#3 Posted : Wednesday, February 22, 2023 5:25:07 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
You can also do this with the Zoom feature of Virtual Sets
See 5:25
mavik
#4 Posted : Wednesday, February 22, 2023 7:29:42 PM(UTC)
mavik
Ohh, I believe what you men is how to have a zoom happening live.
Add the input as usual, right click on the small cog buttom right of that input and select "create virual input". Open the virtual input and change the zoom/position whatever. Merge between the two.
