How to Set Mix Input 2/3/4/... Preview and Outputs with script
Hi Vmix Experts,
I'm trying to set Mix Input 2/3/4/... Preview and Output with a script but can't get it to work.
Here is what I'm trying:
Input.Find("VideoForMix2Preview.mov").Function("PreviewInput", Mix:=1)
It's not working. Any help would be greatly appreciated on how to do this. Thanks!
Is there even a shortcut that can do this ? Not seeing it so far , then again its still early in the year ;-)
Edit: There is :-)
Function: PreviewInput & ActiveInput Input: "theinput" Mix: 1/2/3/4
Joined: 11/23/2020(UTC) Posts: 244  Location: Wichita Thanks: 13 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: doggy  Is there even a shortcut that can do this ? Not seeing it so far , then again its still early in the year ;-)
Edit: There is :-)
Function: PreviewInput & ActiveInput Input: "theinput" Mix: 1/2/3/4 A FYI for anyone looking at this, the Mix number you use in Scripting is the Mix number from the description - 1. It's Zero based in scripting, 1 based in the names. That should save you the hours I spent trying to figure out why my script wasn't working. It will NOT give you an error if you reference a Mix number that doesn't exist.
Joined: 7/1/2020(UTC) Posts: 105  Location: Earth Was thanked: 23 time(s) in 20 post(s)
Edit: There is :-)
Function: PreviewInput & ActiveInput Input: "theinput" Mix: 1/2/3/4 yep, i use them on my streamdeck...
