28 Pages«<1718192021>»
#361 Posted : Saturday, February 11, 2023 9:34:59 PM(UTC)
Originally Posted by: nikosman88 Go to Quoted Post
Ok im not script guru so i am trying to combine things from "here" and "there".. Try not to laugh :p with my logic i do the things
At first i add
dim markout as string = ""
then i add the line that reads markout as first line after activeinput and the script doesnt start. it says object line error. Then i put this line after position line and script start but not work. Then i tried Timeleft= Double.Parse(duration)-Double.Parse(position) to change to Timeleft= Double.Parse(duration)-Double.Parse(markout) or Timeleft= Double.Parse(position)-Double.Parse(markout) some combinations here,dont work
Then i see to xml manually the total time of video (that of course will need to change every time because not all videos are have to be split for example 30minutes exactly) so for the specific video that said markout=1900340 and i wanted to do the "script thing" 8sec before it reaches the markout point to change the triggertime. As value in triggertime i tried to do some mathematical actions and put the result actual duration - markout duration -8sec.. Of course it didnt work and if i have for every video that i need something to do before it ends,to take the calculator, i prefer to do edit real editing in premiere. That`s the way i tried and search..
Why not check on "state" instead of trying calculations etc ;-) (or use a trigger oncompletion instead of a script)
if you want to use it in a script check on status running or completed , or trigger to call a script.
KISS
PS original script is fr doing an action BEFORE a certain position is reached
Best is to stay away from scripting then. Is better to learn than throwing things to a wall and see what sticks
#362 Posted : Saturday, February 11, 2023 10:43:06 PM(UTC)
Originally Posted by: doggy Go to Quoted Post
From a recent request/discussion to trigger something BEFORE a video finishes
Code:
' Checking time left of active input
' and do some stuff at certain time remaining
dim position as string = ""
dim duration as string = ""
dim activeinput as string = ""
dim Timeleft as double = 0
dim triggertime as integer = 2000       '2 seconds before end
dim triggerduration as integer = 2000   'fade duration, could be different than trigger
do while true
   dim xml as string = API.XML()
   x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText)
duration = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@duration").Value)
position = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@position").Value)
if Timeleft < triggertime
  API.Function("SetVolumeFade",Input:=activeinput.tostring(),Value:="0," & triggerduration.tostring())
  ' do whatever one wants to do
end if
sleep(500)
Loop
Adjusted for using MarkOut points
Screenshot 2023-02-11 133611.jpg (95kb) downloaded 15 time(s).
nikosman88 on 2/11/2023(UTC)
nikosman88
#363 Posted : Saturday, February 11, 2023 10:44:00 PM(UTC)
nikosman88
Greece
Edit
Your "markout" script work perfect!!! Thank you very much.
At first i add
KISS
on state or on completion will not work because it says either "running" or "paused". And i want to do something before video ends. Anyway your script is what i wanted and thank you again. Yes i try to learn but i dont have the time or the way to learn everything in vb.net. But im trying to learn and if i know something i will help to this forum because this forum helps me. For example 2 scripts i made myself after searching how
https://forums.vmix.com/...-List-Restart#post106220 and https://forums.vmix.com/...77-Text-files#post106377 simple scripts but for me it took much time to understand how it will work
bilalesb
#364 Posted : Saturday, February 25, 2023 11:28:44 PM(UTC)
bilalesb
Algeria
Hello please i need help
live bloomberg ticker like this
like this
#365 Posted : Sunday, February 26, 2023 1:04:33 AM(UTC)
like this
This is nothing to do with scripting but with GT titles'\A static image does not tell us much regarding the ticker specifics.
Please do an effort to explain/show what exactly your goal is in a proper post/forum
bilalesb
#366 Posted : Monday, February 27, 2023 1:56:44 AM(UTC)
bilalesb
Algeria
like this
this live
take a look i need help to make ticker of bloomberg
#367 Posted : Monday, February 27, 2023 3:46:41 AM(UTC)
Again this is in the wrong forum and post , please post GT title related questions here https://forums.vmix.com/topics/12-GT
gpdipalmerahtimur
#368 Posted : Monday, February 27, 2023 12:14:22 PM(UTC)
gpdipalmerahtimur
Indonesia
Is it possible to know when a SRT Client is Connected via Script? The background is to display LARIX QR Code when there is no Client Connected and Removes it once Connection Established.
Thanks in advance.
nikosman88
#369 Posted : Tuesday, February 28, 2023 6:14:54 AM(UTC)
nikosman88
Greece
Thanks in advance.
Hello. A way to do this is if your srt input when connected has audio. If yes, you can check api xml to see if audio is coming or not and then do what you want to do. A script to do this is, can be like that
Code:
Do while true
x.loadxml(xml)
'set the name of your input
dim AU = (x.SelectSingleNode("//input[@shortTitle='nameyourinputorinputkey']/@meterF1").Value)
'check audio of this input'
If AU > 0 Then
'do whatever you want to do'
ElseIf AU = 0 Then
End if
loop
gpdipalmerahtimur
#370 Posted : Friday, March 3, 2023 3:22:49 PM(UTC)
gpdipalmerahtimur
Indonesia
Hi nikosman88,
Thanks for your help, unfortunately we have flaw on that approach, if Cameraman decided to mute LARIX on his Phone then the action will be triggered falsely.
Huaba
#371 Posted : Thursday, March 23, 2023 8:23:30 AM(UTC)
Huaba
Germany
I've found this script that helped me a lot.
Originally Posted by: titasas Go to Quoted Post
Code:
do while True
 if Input.Find("home-powerplay.gtzip").Text("pp.Text") >= "0:01" then
   API.Function("MultiViewOverlayOn", Input:="scoreboard.gtzip", Value:="1")
 else
   API.Function("MultiViewOverlayoff", Input:="scoreboard.gtzip", Value:="1")
 end if
sleep(500)
Loop
But in my case I need to check if an image is set in the title editor or not.
Unfortunately I do not get this done
My code:
Code:
do while True
 if Input.Find("Whatsapp nur Text").Text("bild.Source") = "" and Input.Find("Whatsapp nur Text").Text("Text.Text") <> "" then
   API.Function("OverlayInput1In",Input:="Whatsapp nur Text")
 elseif Input.Find("Whatsapp nur Text").Text("bild.Source") <> "" and Input.Find("Whatsapp nur Text").Text("Text.Text") = "" then
   API.Function("OverlayInput1In",Input:="Whatsapp nur Bild")
 else API.Function("OverlayInput1In",Input:="Whatsapp Bild und Text")
 end if
sleep(500)
Loop
I have already tried a few things.
.Source("bild.Source")
.Image("bild.Source")
.Pciture("bild.Source")
Can anybody please help me?
Andi
#372 Posted : Thursday, March 23, 2023 8:43:26 PM(UTC)
Originally Posted by: Huaba Go to Quoted Post
My code:
Code:
do while True
 end if
sleep(500)
Loop
Andi
Use checking the vMix API XML file content instead
Huaba
#373 Posted : Thursday, March 23, 2023 9:28:11 PM(UTC)
Huaba
Germany
Do you have a code example for this, please?
#374 Posted : Thursday, March 23, 2023 10:12:01 PM(UTC)
You are in the right post subject allread, start from the top
nikosman88
#375 Posted : Friday, March 24, 2023 7:38:01 AM(UTC)
nikosman88
Greece
Hello guys. A great tool for script by dummies or for general vb.net code that we dont know how to do or if possible to do is Chatgpt AI. If we give it, the details it needs, it can do a big piece of our vb.net script. I needed a script that will find if a specific input in vmix exists and if exists to rename it to a random name. The result after telling chatgpt for vmix xml file and some more details is this
Code:
Dim xml As String = API.XML()
Dim x As New System.Xml.XmlDocument()
x.LoadXml(xml)
Dim apiUrl As String = "http://127.0.0.1:8088/api"
Dim inputNodeBack1 As XmlNode = x.SelectSingleNode("//input[@title='back1']")
If inputNodeBack1 IsNot Nothing Then
    Dim randomName As String = "Input" & Guid.NewGuid().ToString().Substring(0, 5)
    inputNodeBack1.Attributes("title").Value = randomName
    inputNodeBack1.Attributes("shortTitle").Value = randomName ' update shortTitle as well
    Dim client As New WebClient()
    Dim xmlString As String = x.OuterXml
    client.Headers("Content-Type") = "application/xml"
    client.UploadString(apiUrl, "POST", xmlString)
    API.Function("SetInputName", Input:="back1", Value:=randomName)
    Console.WriteLine("Input 'back1' renamed to '" & randomName & "'")
Else
    Console.WriteLine("Input 'back1' does not exist")
End If
Of course a vb.net person script guru can make something better but for us who dont know how and where to search chatgpt can help a lot. What impressed me the most was that it created a script that told the vmix console that the input file had been renamed, but in reality nothing changed inside vmix. I told it that, and it replied that "vmix probably doesn't support file renaming while it's running." Then I thought of telling it that vmix does support it and i give to it the command "API.Function("SetInputName", Input:="My input", Value:="My new input name")" and he fixed the command on his own, as you can see in the above script."
thanks 1 user thanked nikosman88 for this useful post.
Nguyendung on 1/5/2024(UTC)
Salvatore
#376 Posted : Wednesday, March 29, 2023 9:41:49 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
i was wondering if it's possible to play a certain Soundfile from a List (not PlayList) without playing in PGM
For example, my list contains 3 sound files. I would like to play file two detached from PGM
MyList
Sound1.wav
Sound2.wav
Sound3.wav
This Play the List, but how to select the file?:
Code:
API.Function("Play", Input:="MyList")
This don't work:
Code:
API.Function("Play", Input:="MyList", Value:="Sound2.wav")
#377 Posted : Wednesday, March 29, 2023 10:01:05 PM(UTC)
MyList
Sound1.wav
Sound2.wav
Sound3.wav
The Shortcut Function Reference show only this to play a list:
Code:
API.Function("ListPlayOut", Input:="MyList")
This Play the List:
Code:
But how to select the file?
you cant unless manually
What do you mean by detached/not playing from PGN? As in not "captured" in the output ?
Salvatore
#378 Posted : Wednesday, March 29, 2023 10:10:15 PM(UTC)
Salvatore
Italy
i want to play the sounds on AudioOutput B
#379 Posted : Wednesday, March 29, 2023 10:20:13 PM(UTC)
Use audio as regulare inputs and set it to bus B
nikosman88
#380 Posted : Wednesday, March 29, 2023 10:26:13 PM(UTC)
nikosman88
Greece
Uncheck from audio settings that belong to your list the button M and select B. Then press play manually and it will start play. By commands you can do it this way
1. Check audio in your list so it will be green the button
2.Uncheck button M
3. Make a script like this that will uncheck the M and select the B bus and then a shortcut for it
Code:
API.Function("AudioBusOff", Input:="1", Value:="M")
API.Function("AudioBusOn", Input:="1", Value:="B")
API.Function("Play", Input:="1")
of course you can make more commands like selectindex for specific clip in your list
thanks 2 users thanked nikosman88 for this useful post.
doggy on 3/29/2023(UTC), Salvatore on 3/29/2023(UTC)
Guest (22)
