	GT
	File Not Found: Source:ImportPSD Error Message
                Hello all, Recently I've been hit with this error message when trying to import PSDs into GT.  This occurs with every PSD I try, whether it's text only or an old PSD that worked in the past. I have even tried doing a clean install of vmix to no avail. I would like to avoid creating all of my text boxes manually, so any help is greatly appreciated.
 Joined: 3/31/2022(UTC) Posts: 4  Location: Smithfield, RI Thanks: 4 times
                Don't know if you ever got this figured out, but when opening photoshop to create your PSD, choose NEW and then Film & Video templates.  Choose the HD template and on the right be sure to set the Pixel ratio to HD/DV (1.33).
  When I did this, it created a template for my edits and imported correctly.  Using the Square pixels option fails with message you saw.
  Tried to change the Pixel ratio on an existing PSD and it's a bit of a mess...better to start clean.  Then you can edit the layers of PSD in GT title editor or right in Title Edit interface in vMix.
  cheers S
	GT
