Hello everyone I am currently trying to activate the green checkbox in my Video List Input with a Script There is no shortcut function for that and no documentation for that button so I just tried some random code but with no effect. Can anyone help me figure out what could work to enable or disable one/multiple boxes in a list? Below in the picture I am looking at the xml file of vmix to see the state of the items in the List They say either "selected" or enabled="false" and when they are selected there is nothing I was expecting that enable="true" may work unfortunately I am not that familiar with the code syntax  vmix.jpg (177kb) downloaded 5 time(s).
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Hello. What do you want to achieve? Im not a script guru but if your goal is to play a file in a list and only this, you can do a simple "Select index" and then "cut" or "play" script with autonext in the list disabled. And if you want sometime to play 2 continouous files you can enable "Autonext" with a shortcut and disable it after.This way you can have all the time all files in the list enabled and play whatever you want. This is the way i do it Or if you want to do this in a more complicated way for example to play a next file that is not after the active file, maybe you can write a script that checks the active file and decides what to do next There are some examples in this section https://forums.vmix.com/...86-Scripting-for-Dummies
