Feature Requests
Open Broadcaster Software on Vmix13
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
Hi martin, Can you add this on vmix 13 ? http://obsproject.com/alternative to the adobe encoder. very nice indeed . using NVENC . GPU processing not CPU Cheers, PFBM
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
They don't provide a command line interface, so there is no way to automate its use with vMix. And the license agreement prevents it being incorporated in vMix directly.
Also, any GPU processing for encoding is going to cause some big performance problems for vMix so it is not recommended.
Martin vMix
admin wrote:Hi,
Martin vMix if you have a powerfull graphic card.... or..... not ? :) yes vmix eats a lot of gpu power.... and its great !! testing with a GTX750
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
admin wrote:Hi,
Martin vMix They do actually provide profile selection and starting the stream using command line: https://obsproject.com/f...eters-command-line.9805/Regards, Dundurs
Joined: 4/24/2014(UTC) Posts: 15 Location: Boston, MA
admin wrote:Hi, And the license agreement prevents it being incorporated in vMix directly.
That's fairly standard... however that doesn't prevent you from interfacing to it, once the client has downloaded/installed it separately.
Feature Requests
