PFBM
#1 Posted : Thursday, June 26, 2014 8:45:08 AM(UTC)
PFBM
Hi martin,
Can you add this on vmix 13 ?
http://obsproject.com/
alternative to the adobe encoder. very nice indeed .
using NVENC . GPU processing not CPU
Cheers,
PFBM
#2 Posted : Thursday, June 26, 2014 8:56:19 AM(UTC)
Was thanked: 4741 time(s) in 1627 post(s)
They don't provide a command line interface, so there is no way to automate its use with vMix.
And the license agreement prevents it being incorporated in vMix directly.
Also, any GPU processing for encoding is going to cause some big performance problems for vMix so it is not recommended.
PFBM
#3 Posted : Thursday, June 26, 2014 9:16:41 AM(UTC)
PFBM
if you have a powerfull graphic card.... or..... not ? :)
yes vmix eats a lot of gpu power.... and its great !!
testing with a GTX750
dundurs
#4 Posted : Thursday, June 26, 2014 12:23:13 PM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
They do actually provide profile selection and starting the stream using command line: https://obsproject.com/f...eters-command-line.9805/
Dundurs
drjoeblack
#5 Posted : Saturday, July 5, 2014 11:33:47 AM(UTC)
drjoeblack
That's fairly standard... however that doesn't prevent you from interfacing to it, once the client has downloaded/installed it separately.
