tgdzapa1
#1 Posted : Thursday, January 26, 2023 8:07:05 PM(UTC)
tgdzapa1
Hello
Until today I could always avoid this problem :-) .
But now I have to make 2 streams, one stream with 720p25 and at the same time one stream with 1080p50. Is that possible?
I have not figured out how to do this. Does anyone know if this is possible?
Best regards
Patrick
Peter1000
#2 Posted : Thursday, January 26, 2023 8:49:32 PM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
as far as i know, you can only change the resolution per stream (cog icon next to Quality in the streaming settings), the framerate is always the project framerate.
tgdzapa1
#3 Posted : Thursday, January 26, 2023 9:06:37 PM(UTC)
tgdzapa1
Thanks Peter.
I have since figured it out myself :-).
External and external 1 are = Output 1 and Output 2.
So 2 different frame rates can be selected. With the Streams then only the correct Output (1 or 2) select. Then it works.
richardgatarski
#4 Posted : Friday, January 27, 2023 1:52:24 AM(UTC)
richardgatarski
[edit: removed my note about that it was not post]
There are many other options, depending you your budget and needs. You can use https://support.restream...cles/760428-transcoding, at a cost but will offload your PC. Or you can do it with another streaming app, e.g. OBS. Another option is to use a hardware encoder, e.g. https://www.magewell.com/ultra-stream
elvis55
#5 Posted : Friday, January 27, 2023 2:23:02 AM(UTC)
elvis55
Views messages in topic : 456
Switzerland
Eventuell
Adobe Flash Media Live Encoder 3.2
https://adobe-flash-medi...1.software.informer.com/
tgdzapa1
#6 Posted : Friday, January 27, 2023 2:34:14 AM(UTC)
tgdzapa1
Originally Posted by: elvis55 Go to Quoted Post
Eventuell
Ohh nein :-), der ist out of work! Dann lieber mit OBS
