2 streams with 2 different frame rates
Joined: 1/21/2014(UTC) Posts: 82 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hello
Until today I could always avoid this problem :-) .
But now I have to make 2 streams, one stream with 720p25 and at the same time one stream with 1080p50. Is that possible?
I have not figured out how to do this. Does anyone know if this is possible?
Best regards Patrick
Joined: 1/25/2019(UTC) Posts: 331  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
as far as i know, you can only change the resolution per stream (cog icon next to Quality in the streaming settings), the framerate is always the project framerate.
Originally Posted by: Peter1000  as far as i know, you can only change the resolution per stream (cog icon next to Quality in the streaming settings), the framerate is always the project framerate. Thanks Peter. I have since figured it out myself :-). External and external 1 are = Output 1 and Output 2. So 2 different frame rates can be selected. With the Streams then only the correct Output (1 or 2) select. Then it works.
Originally Posted by: elvis55  Ohh nein :-), der ist out of work! Dann lieber mit OBS
