AlbertoBCN
#1 Posted : Monday, November 28, 2022 8:52:11 PM(UTC)
AlbertoBCN
Most of the tally systems are reading info from the main mixer.
However, nowadays we use submixers in 100% of our productions (MIX 2, 3, 4 and more with version 26). If camera is live in a submixer, it makes sense not to light up a tally until the submixer is put on the main program.
So, I think it would be just perfect if the tally on the main program shows when an input is live in a submixer, AND this submixer is live on program.
This is: we use MIX2 for a picture in picture composition. If CAM1 is live on MIX2, AND MIX2 is ON AIR, TALLY for the main program should send the signal ON for CAM1.
Does this make sense?
thanks 3 users thanked AlbertoBCN for this useful post.
xun on 12/4/2022(UTC), vvcvvc on 1/29/2023(UTC), khiry222 on 10/4/2024(UTC)
xun
#2 Posted: : Sunday, December 4, 2022 1:13:53 PM(UTC)
xun
Germany
YES!!!
I have the same problem ... my solution is a app reading the vmix-api and send the tally signal to all cam's .. incl. multiple on air cam's. ... but, its not the best way.
JimJim
XUN
thanks 1 user thanked xun for this useful post.
seb666 on 1/21/2023(UTC)
jet
#3 Posted : Thursday, December 22, 2022 1:14:24 PM(UTC)
jet
Was thanked: 39 time(s) in 37 post(s)
+1
Yannick
#4 Posted : Monday, January 2, 2023 11:01:30 PM(UTC)
Yannick
+1
AudioGreg
#5 Posted : Wednesday, January 4, 2023 9:19:32 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
+10!
dmwkr
#6 Posted : Wednesday, January 4, 2023 6:54:13 PM(UTC)
dmwkr
+1
seb666
#7 Posted : Saturday, January 21, 2023 6:47:38 AM(UTC)
seb666
It's not only about tally but the possibility to have triggers of any kind enabled. It should be possible to decide if triggers work for each Mix seperately.
This has an effect on audio switching for eg vMixCalls in a PiP, tally in vMix but also via NDI (we use NDI tally for our Panasonic PTZ) as well as triggers in an input.
I know that there are many use cases where you dont want triggers, but also multiple where they are needed to use the sub mixes in a good way.
mavik
#8 Posted : Tuesday, January 24, 2023 5:11:37 AM(UTC)
mavik
+1
vvcvvc
#9 Posted : Sunday, January 29, 2023 12:06:53 AM(UTC)
vvcvvc
Estonia
+1
richardgatarski
#10 Posted : Sunday, January 29, 2023 12:34:02 AM(UTC)
richardgatarski
+1
And I suggest it could be implemented as a right-click option in the Mix Input. For example, "Forward tallys to Output" or something similar.
Peter Berglund
#11 Posted : Monday, January 30, 2023 8:09:42 PM(UTC)
Peter Berglund
Sweden
+1
udo.schneider
#12 Posted : Tuesday, March 21, 2023 11:38:06 PM(UTC)
udo.schneider
Germany
+1
Same here. I tried to address this by managing Tally via TallyArbiter - but the config effort is to high IMHO.
I basically reaplced submixes with Companion's "Routable Multiview" Feature (see https://trendmicro-my.sh...DwtYaHEROhPubQ?e=vHKT7d) for a recent event. This isn't as nice because I ended up with CUT transitions only ... but it did kind of work.
I do however have usecases where I cannot/don't want to replace Submixes but still need tally ... Esp. in virtual set environments (think IMAG in virtual sets :-) )
CU,
Udo
spino
#13 Posted : Wednesday, March 22, 2023 6:34:09 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
+1
Catmix
#14 Posted : Thursday, April 6, 2023 7:28:12 AM(UTC)
Catmix
Andorra
+1
scanscan
#15 Posted : Thursday, May 4, 2023 9:19:18 PM(UTC)
scanscan
+1
DannyGudkov
#16 Posted : Saturday, September 7, 2024 2:53:40 AM(UTC)
DannyGudkov
+1
khiry222
#17 Posted : Friday, October 4, 2024 6:40:38 AM(UTC)
khiry222
New Zealand
+10 please need this
Buri
#18 Posted : Tuesday, April 21, 2026 6:51:29 PM(UTC)
Buri
Slovakia
+1 We started to using NDI instead of classic SDI/Decklinks and we do mixing inside MIX 2 before all graphics applied on MIX 1 but our tally on Canon PTZs stopped working even MIX 2 is part of MIX 1 and tally is visible in multiview. :/
