afonia
#1 Posted : Tuesday, January 24, 2023 2:04:45 AM(UTC)
afonia
Friends, need help.
Soccer live. When referee adds additional time (injury time) I want just to press 3 on NumPad and +3 text appears in the box (or +5 and 5 appears etc). I don't want to create 9 shortcuts for aech minute. Is it possible?
Currently I "Edit Title" manually to 3 and then show this element (visible text + visible image) with A shortcut. I want to set text+show entere element with just one shortcut on NumPad (or at least set text with one shorcut and then show element with my current A shortcut)
avsoundguy
#2 Posted : Tuesday, January 24, 2023 2:41:51 AM(UTC)
avsoundguy
Just use Set Text and use +=1 to increment the number by 1, each time you use the shortcut it will count up by 1, I always use another key with -=1 in case I accidentally enter the wrong number
afonia
#3 Posted : Tuesday, January 24, 2023 3:02:23 AM(UTC)
afonia
I use it already for Score_home and score_away. If there are no other suggestions I will use this method but would like my option to be implemented. Thanks you.
#4 Posted : Tuesday, January 24, 2023 3:32:17 AM(UTC)
Afaik you will have to use 9 shortcuts. (how else would you create the 1-9 choice)
Could of course use 2 shortcuts to add/subtract till you reach the desired number (displayed in a unused title for reference) and then one shortcut to display it (using dynamic value)
afonia on 1/24/2023(UTC)
afonia
#5 Posted : Tuesday, January 24, 2023 7:23:15 PM(UTC)
afonia
Seems this is the only way so far. It's still good for me. Thanks you!
My text is: +3'
I need to add/subtract only number, and + and ' should always remain. Is it possible somehow?
#6 Posted : Tuesday, January 24, 2023 8:07:24 PM(UTC)
My text is: +3'
Calling a small script to do this formatting using the same source of the "variable"
as an example where Headline.Text is holding the variable you adjusted
Code:
API.Function("SetText", Input:="Title.gtzip", SelectedName:="Description.Text", value:="+" & Input.Find("Title.gtzip").Text("Headline.Text") & "'")
either you call it or put it within a loop to automate the updating when time is changed
Is up to you to figure out how to manipulate the process to suit you best (and do some research in this forum ;-) )
afonia
#7 Posted : Tuesday, January 24, 2023 8:35:58 PM(UTC)
afonia
Code:
Almost done.
Code:
API.Function("SetText", Input:="Scoreboard MF red.gtzip", SelectedName:="Injury time.Text", value:="+" & Input.Find("Scoreboard MF red.gtzip.gtzip").Text("Headline.Text") & "'")
Also I have shortcut for Injury time.Text SetText +=1
But can't understand how to link this shortcut to this script. What is "Headline.Text"? Now I have just +' in scoreboard.
Sorry, I am just 2 weeks in vMix (but already learned a lot and made my 1st futsal live full of automated graphics).
mavik
#8 Posted : Tuesday, January 24, 2023 8:59:07 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
I would do a simple csv file with what you want to display
text,on/off
0,0
+1,1
+2,1
+3,1
For each 1-9 shortcut you jump to the according row in the file.
#9 Posted : Tuesday, January 24, 2023 9:02:45 PM(UTC)
Almost done.
Code:
Headline.Text is just the name reference of one of the basic vMix titles text fields i used as example that is holding the basic value/number. you can make your own title with your own names etc
As i said ,research in this forum a bit , follow the vMix video torials, documentation etc , best way to learn and understand and make your own solutions
afonia
#10 Posted : Tuesday, January 24, 2023 11:52:27 PM(UTC)
afonia
Made simplier.
Drew this red box with + ' already. So just insert number between with SetText +=1.
Thank you all.
P.S. Anyway, learning how to make it with script for other cases.
#11 Posted : Wednesday, January 25, 2023 3:17:27 AM(UTC)
Made simplier.
Thank you all.
is an option as long as you have single digit and alignment is perfect ;-)
Guest (11)
