How can you tell on an input what Mix Number it is?
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
On the Settings Window is there a way to see what Mix Number a Mix Input is?
I am trying to keep straight several Mix Inputs and I did not name them Mix 1 Mix 2 ect. Is there a way to find the Mix # when you go into the settings?
Thanks for your help.
Originally Posted by: RichShumaker  On the Settings Window is there a way to see what Mix Number a Mix Input is?
Thanks for your help. Mixes are autonumbered if you dont giv them a specific name The details of them can be found in the API XML if you havent named them their number will adapt to their position in your input list if you move them
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4794 time(s) in 1646 post(s)
It's written right there at the top of the General tab.
Originally Posted by: admin  It's written right there at the top of the General tab. Found it after I posted. Just got back to update and thanks. I am renaming my inputs so I can find the Mix # without opening every Mix.
Originally Posted by: RichShumaker  Originally Posted by: admin  It's written right there at the top of the General tab. Found it after I posted. Just got back to update and thanks. I am renaming my inputs so I can find the Mix # without opening every Mix. Crap I also confirmed that moving them renumbers them based on Order So once you set up your Mixes with Shortcuts you can not move them. This is not so different then using Numbers for Inputs except I was not expecting that for some reason. Makes perfect sense though.
