RichShumaker
#1 Posted : Saturday, January 14, 2023 8:34:58 AM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
On the Settings Window is there a way to see what Mix Number a Mix Input is?
I am trying to keep straight several Mix Inputs and I did not name them Mix 1 Mix 2 ect.
Is there a way to find the Mix # when you go into the settings?
Thanks for your help.
#2 Posted : Saturday, January 14, 2023 9:12:24 AM(UTC)
Mixes are autonumbered if you dont giv them a specific name
The details of them can be found in the API XML
if you havent named them their number will adapt to their position in your input list if you move them
#3 Posted : Saturday, January 14, 2023 12:13:50 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
It's written right there at the top of the General tab.
eduardocfs on 1/14/2023(UTC), RichShumaker on 1/14/2023(UTC)
RichShumaker
#4 Posted : Saturday, January 14, 2023 2:08:35 PM(UTC)
RichShumaker
Found it after I posted.
Just got back to update and thanks.
I am renaming my inputs so I can find the Mix # without opening every Mix.
RichShumaker
#5 Posted : Saturday, January 14, 2023 2:10:16 PM(UTC)
RichShumaker
Crap I also confirmed that moving them renumbers them based on Order So once you set up your Mixes with Shortcuts you can not move them.
This is not so different then using Numbers for Inputs except I was not expecting that for some reason.
Makes perfect sense though.
