cchhita
#1 Posted : Saturday, January 14, 2023 2:18:36 AM(UTC)
cchhita
I have a data table I am pulling into GT Title Designer and have written a script to change the input source. This works great for the first row, but I want to be able to loop through all rows from my table and execute the command for all rows.
Is there any easy way to do that?
My Table contains 3 columns, Input Number, Input Name, and Source.
I will have 10-20 rows, and I would like to run a script to execute each of those rows in one command.
#2 Posted : Saturday, January 14, 2023 3:09:06 AM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
DataSOurceNextRow fubction within the script ?
Else more info needed
cchhita
#3 Posted : Saturday, January 14, 2023 7:19:31 AM(UTC)
cchhita
I tried to use some code I found in the Scripting for Dummies section, but it does not advance to the next row. Here is what I have:
dim dataSource as String = setting.SelectSingleNode("/event/data-source/@name").Value
dim x as integer
Dim Index as integer =0
Do while Index <=6
for x = 1 to 5
API.Function("DataSourceSelectRow", Value:="dataSource,x")
next x
index +=1
loop
I have code that will execute the first row, and that works great, but I want it to loop through all rows and execute every row in the datasource
#4 Posted : Saturday, January 14, 2023 8:57:15 AM(UTC)
Think we are missing some explanation to the above
advancing to next row has been explained using the appropriate function
changing the inputsource based on the datatable is th confusing part , Care to explain pls
cchhita
#5 Posted : Thursday, January 19, 2023 6:19:10 AM(UTC)
cchhita
I was trying to have my script read an excel spreadsheet, where someone would enter in an NDI data input name, and when the script was run, it would that VMIX input to that particular NDI input.
I now have it working the way I need it.
part of my code that I needed to write looks like this:
for x = 1 to totalRowCount
API.Function("NDISelectSourceByName", Input :=ndiInputNumber, Value := ndiInputName)
next x
