Scripting DataSource multiple rows
Joined: 4/14/2020(UTC) Posts: 17  Location: Dallas, TX Thanks: 5 times
I have a data table I am pulling into GT Title Designer and have written a script to change the input source. This works great for the first row, but I want to be able to loop through all rows from my table and execute the command for all rows.
Is there any easy way to do that? My Table contains 3 columns, Input Number, Input Name, and Source. I will have 10-20 rows, and I would like to run a script to execute each of those rows in one command.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: cchhita  I have a data table I am pulling into GT Title Designer and have written a script to change the input source. This works great for the first row, but I want to be able to loop through all rows from my table and execute the command for all rows.
DataSOurceNextRow fubction within the script ? Else more info needed
I tried to use some code I found in the Scripting for Dummies section, but it does not advance to the next row. Here is what I have:
dim dataSource as String = setting.SelectSingleNode("/event/data-source/@name").Value dim x as integer Dim Index as integer =0 Do while Index <=6 for x = 1 to 5 API.Function("DataSourceSelectRow", Value:="dataSource,x") next x index +=1 loop
I have code that will execute the first row, and that works great, but I want it to loop through all rows and execute every row in the datasource
Quote:have written a script to change the input source My Table contains 3 columns, Input Number, Input Name, and Source. Think we are missing some explanation to the above advancing to next row has been explained using the appropriate function changing the inputsource based on the datatable is th confusing part , Care to explain pls
I was trying to have my script read an excel spreadsheet, where someone would enter in an NDI data input name, and when the script was run, it would that VMIX input to that particular NDI input.
I now have it working the way I need it.
part of my code that I needed to write looks like this:
for x = 1 to totalRowCount API.Function("NDISelectSourceByName", Input :=ndiInputNumber, Value := ndiInputName) API.Function("DataSourceSelectRow", Value:="dataSource,x") next x
