2 Pages<12
Salvatore
#21 Posted : Friday, December 30, 2022 10:08:31 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Originally Posted by: bar807 Go to Quoted Post
Is it possible to call multiple functions in a single API call using the URL feature on stream deck? like for example the below? I need to call the below functions using 1 button
API.Function("PlayPause",Input:="Countdown.gtzip")
Sleep(200)
API.Function("SetDynamicValue1",Value:="Started")
Add a shortcut, Select the „ScriptStartDynamic“-Function
studiog04
#22 Posted : Friday, January 27, 2023 10:57:53 PM(UTC)
studiog04
United Arab Emirates
Hello!
I don't know guys if I choose the right topic for this question. Sorry in advance.
I work with vMix (last version for today) + just bought Stream Deck, which is connected by Stream Deck.
I can add kind of like shortcuts with the vMix plugin via Stream Deck app. But everytime I press these buttons, it shows me an exclamation point.
More than that, vMix doesn't show me Stream Deck in Shortcuts settings. How can I connect Stream deck to vMix?
What's the problem?
BTW, 3-4 month ago it was working, I could change Preview/Output, set the volume and etc. Nowadays it's not like that.
Thanks in advance guys.
WaltG12
#23 Posted : Saturday, January 28, 2023 11:24:11 AM(UTC)
WaltG12
Honestly, if you're trying to do something basic/simple & you can set a reserved IP for your vMix machine, your best option is to just use the "Website" function under "System", use the web command URL, and check the "GET request in background" box.
Pavel
#24 Posted : Saturday, January 28, 2023 7:46:15 PM(UTC)
Pavel
Good day. Try Bitfocus Companion. It is easy to program and control directly with feedback.
It can export and save settings and much more. I have been using more than a year and maximum satisfaction. At the last event I had 2x Atem, VMIX and feedback under one button.
2 Pages<12
