Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Not sure if this is a bug or feature.
I save my vMix with Input 2 Audio ON.
When I load it Input 2 Audio is OFF. I have done this 3 or 4 times so far
By On/Off I mean the Toggle is Green or Grey(Green On / Grey Off)
It is an NDI Input and I am using vMix Basic HD. I am on the most recent version (no updates are showing). 26.0.0.23 X64
Joined: 11/14/2012(UTC) Posts: 391  Location: Finland Thanks: 249 times Was thanked: 34 time(s) in 32 post(s)
It is an NDI Input and I am using vMix Basic HD. I am on the most recent version (no updates are showing). 26.0.0.23 X64 Have seen similar problem. Saved preset with NDI audio OFF, after reloading it was ON..
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
Check the Automatic Audio Mixing (two arrows) button in the audio mixer is turned off. If you have an input in preview, its audio will be turned off when loading the preset when this button is on.
This is by design, as only live inputs will have audio turned on in this mode.
So double check the audio mixer.
vMix 26 Preview (26.0.0.27) Released!
* Added Preview input (yo dawg meme intensifies) * Added CBR support for SRT * Fixed distorted image when using HEVC SRT inputs in Replay. Note that HEVC is strongly discouraged for use with replay due to its very high CPU usage. * Added support for X-Keys T-Bar Module Red/Blue LEDs * Added support for multi-channel audio when using External Output with Bluefish cards
 5 users thanked admin for this useful post.
Rank:: Advanced Member
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Thanks Martin for adding Preview as Input, that will help a lot to build Custom MultiView. But there is 1 thing left, can we display Master Audio Meter in an Input?
Joined: 8/22/2021(UTC) Posts: 48   Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: admin  vMix 26 Preview (26.0.0.27) Released! * Added support for X-Keys T-Bar Module Red/Blue LEDs I have an SB124T device that is regularly used for controlling analogway video mixers. But technically it is a regular Xkeys XK124Tbar device with a different PID (1307). It is the one with the tbar and red/blue LEDs. Does anybody know if that should be accessible by vmix now? Because I just tried it and it doesn't work. Any ideas? Would be nice to have the option to use it with vmix sometimes.
Joined: 9/21/2018(UTC) Posts: 23 Location: United Arab Emirates
CBR much appreciated to match CBR for RTMP. Any chance we'll see PID selection for the multi-track audio option in the future? Keep up the great work vMix team :). Can't wait for the release! Originally Posted by: admin  vMix 26 Preview (26.0.0.27) Released!
Hi Martin,
I think it has been a while (more than 2 weeks) since the last issue reported. Does build 27 can be considered close to Final Release?
Joined: 12/13/2017(UTC) Posts: 3 Location: Raleigh, NC
We are seeing a green bar on replay output a and b when using SRT feeds as direct replay inputs. SRT from kiloview on site 6mbps 1080 59.97p into vmix with hardware encoding OFF. When we utilize and NDI output for the replay input we do not see this green bar. We have recreated this anomaly on 3 different vmix machines using .27 We also experienced vmix closing down without warning last weekend after acknowledging an error that popped up.. something about SRT socket. I assume its related.. We also put a ticket into support and sent them the support file. I was wondering if anyone else has experienced this? Cheers, Mike
We were able to identify the SRT green line issue with replay and this will be fixed in the next update.
Thanks,
Martin vMix
Hello. Quite strange behavior on one of my notebooks. HP Workstation with NVIDIA Quadro P1000. vmix 26.0.0.27 Streaming is running with quite high CPU 14% Total ~ 67% , but if I just open Task Manager and switch back to vmix window -> CPU drops to 7% Total drops to 14% Looks quite strange....
