bain1320
#1 Posted : Wednesday, August 10, 2022 9:51:24 PM(UTC)
bain1320
Russian Federation
Hello. I desperately need the ability to enable and disable trigger execution using shortcuts!
The situation is this: there is football, the replay function contains a trigger for disabling all overlays on the input, and enabling overlays on the output, but if the replay comes after the goal, then I want to return to the air with a different overlay, not with the one after the usual replay, in which no goal was scored. Or after a replay in stoppage time, I want an additional plate to be displayed after the replay
kirik
#2 Posted : Friday, September 9, 2022 7:13:35 AM(UTC)
kirik
Russian Federation
+1 and activator
hakan_forss
#3 Posted : Saturday, September 17, 2022 11:52:13 PM(UTC)
hakan_forss
Sweden
+1
bain1320
#4 Posted : Thursday, December 22, 2022 2:09:27 AM(UTC)
bain1320
Russian Federation
Colleagues.
I figured out how to get around this problem
Task: after a regular replay, the scoreboard should return to the overlay, and after a goal it should not
I have created several hotkeys for starting a replay: one key for a regular replay, another for a replay after a goal.
The key that starts the replay after a goal also makes the scoreboard transparent, and after the replay is completed, the scoreboard returns to the overlay, but it is not visible, after which I display the graphics I need, and remove the transparent scoreboard. Then, when it is removed from the overlay, I make it visible again
thanks 1 user thanked bain1320 for this useful post.
nikosman88 on 12/22/2022(UTC)
nikosman88
#5 Posted : Thursday, December 22, 2022 6:16:22 AM(UTC)
nikosman88
Greece
Was thanked: 98 time(s) in 94 post(s)
+1
Most times somehow many things in vmix are possible to be done but not everyone can think "outside of the box" to do some things that seem to be simple. For example a shortcut like this
Ario
#6 Posted : Monday, December 26, 2022 6:13:26 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
+1
majorsky
#7 Posted : Sunday, January 25, 2026 10:48:23 PM(UTC)
majorsky
+1
Alain Lahaye
#8 Posted : Saturday, March 14, 2026 2:08:54 AM(UTC)
Alain Lahaye
+1
monamiga
#9 Posted : Tuesday, March 17, 2026 2:43:00 PM(UTC)
monamiga
Philippines
+1
mavik
#10 Posted : Tuesday, March 17, 2026 6:21:34 PM(UTC)
mavik
+1
Guest (5)
