Feature Requests
Shortcut to enable and disable a trigger
Joined: 10/12/2017(UTC) Posts: 13   Location: Astrakhan Was thanked: 1 time(s) in 1 post(s)
Hello. I desperately need the ability to enable and disable trigger execution using shortcuts! The situation is this: there is football, the replay function contains a trigger for disabling all overlays on the input, and enabling overlays on the output, but if the replay comes after the goal, then I want to return to the air with a different overlay, not with the one after the usual replay, in which no goal was scored. Or after a replay in stoppage time, I want an additional plate to be displayed after the replay
Joined: 10/25/2018(UTC) Posts: 43  Location: Moscow Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
Colleagues. I figured out how to get around this problem Task: after a regular replay, the scoreboard should return to the overlay, and after a goal it should not I have created several hotkeys for starting a replay: one key for a regular replay, another for a replay after a goal. The key that starts the replay after a goal also makes the scoreboard transparent, and after the replay is completed, the scoreboard returns to the overlay, but it is not visible, after which I display the graphics I need, and remove the transparent scoreboard. Then, when it is removed from the overlay, I make it visible again
 1 user thanked bain1320 for this useful post.
+1 Most times somehow many things in vmix are possible to be done but not everyone can think "outside of the box" to do some things that seem to be simple. For example a shortcut like this
Thanks: 186 times Was thanked: 20 time(s) in 17 post(s)
Joined: 7/4/2016(UTC) Posts: 23  Location: Munich Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Joined: 3/1/2022(UTC) Posts: 8  Location: Liège Thanks: 1 times
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 171 times Was thanked: 3 time(s) in 2 post(s)
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Feature Requests
