Joined: 9/12/2021(UTC) Posts: 23   Location: Medicine Hat, AB Thanks: 1 times
So I'm not sure if I can do this... I haven't been able to, and it's not clear.
When I do a service (I do church and funeral services using VMix), I have lower thirds and other titles that I pre-load data into. Sometimes I have to add titles after the initial batch of titles.
It would be REALLY nice if there was some way to, after entering a new title, drag it up into, say, 2nd position... so that I can keep my title progression in order in the title-edit box.
Maybe there's a better way of switching between pre-loaded titles, I dunno. But in my experience, I choose them from inside the title.
Reordering them would make life just that little bit easier. :)
When you add a title input you get to the title editor (where you change the default values to something you wanna have). There is a plus at the buttom and a export and import if you like. You can use that. Second option is using a datasource that holds the titles. You can change them while running if you need last minute edits.
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
+1
(Have this issue frequently... I like to have the names in the order they appear in a show. And that order changes during rehearsals... So a simple way of rearranging the order in the built in title editor would be neat.)
