Dave Cruickshank
#1 Posted : Saturday, December 17, 2022 5:36:15 AM(UTC)
Dave Cruickshank
Canada
So I'm not sure if I can do this... I haven't been able to, and it's not clear.
When I do a service (I do church and funeral services using VMix), I have lower thirds and other titles that I pre-load data into.
Sometimes I have to add titles after the initial batch of titles.
It would be REALLY nice if there was some way to, after entering a new title, drag it up into, say, 2nd position... so that I can keep my title progression in order in the title-edit box.
Maybe there's a better way of switching between pre-loaded titles, I dunno. But in my experience, I choose them from inside the title.
Reordering them would make life just that little bit easier. :)
mavik
#2 Posted : Saturday, December 17, 2022 5:44:50 AM(UTC)
mavik
When you add a title input you get to the title editor (where you change the default values to something you wanna have). There is a plus at the buttom and a export and import if you like. You can use that.
Second option is using a datasource that holds the titles. You can change them while running if you need last minute edits.
Peter Berglund
#3 Posted : Tuesday, December 20, 2022 11:34:17 PM(UTC)
Peter Berglund
Sweden
+1
(Have this issue frequently... I like to have the names in the order they appear in a show. And that order changes during rehearsals... So a simple way of rearranging the order in the built in title editor would be neat.)
