MegaFlash
#1 Posted : Monday, July 12, 2010 2:23:59 AM(UTC)
MegaFlash
First of all THANK YOU you just saved my life... My Newtek VT[5] broke down at my event and I was able to use your software. What would be awesome is the ability to load SWF files. I am using those to show live informations... Right now I have hook a second PC and getting the flash file played in a windows and using your remote connection. Anyhow I will buy your software in a week or so.
Thank again...
P.S. if you want to see live streaming I am doing (it is a horse show)... www.jumpingblainville.com and then click on the live feed link (will be up starting from 7h30am to about 5pm..GTM-5 on the July 11th, 2010)
#2 Posted : Tuesday, July 13, 2010 2:24:09 AM(UTC)
Thanks for your comments and suggestions.
Due to the proprietary nature of swf and flash it is difficult to add support for these formats to vMix.
I recommend you use a flash video converter to convert these files into a more suitable format such as MPEG2.
One such program is the Prism Video Converter:
http://www.nchsoftware.com/prism/
MegaFlash
#3 Posted : Tuesday, July 13, 2010 9:28:41 AM(UTC)
MegaFlash
Converting them into MPEG2 will render my live text inexistant...
What I would like to accomplish is having a way to add live text from a DB (using mask). I don't mind loading an other format you would recommend but it needs to be able to be updated live...:)...
Keep up the good work, cheers...
#4 Posted : Thursday, July 15, 2010 9:12:39 PM(UTC)
I've been able to get SWF into vMix using the Flash player for Internet Explorer.
So this feature should appear in the next version...
MegaFlash
#5 Posted : Friday, July 16, 2010 8:14:34 AM(UTC)
MegaFlash
Wow....Really cool...:)
