Hi, First of all THANK YOU you just saved my life... My Newtek VT[5] broke down at my event and I was able to use your software. What would be awesome is the ability to load SWF files. I am using those to show live informations... Right now I have hook a second PC and getting the flash file played in a windows and using your remote connection. Anyhow I will buy your software in a week or so. Thank again... P.S. if you want to see live streaming I am doing (it is a horse show)... www.jumpingblainville.com and then click on the live feed link (will be up starting from 7h30am to about 5pm..GTM-5 on the July 11th, 2010)
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
Hi, Thanks for your comments and suggestions. Due to the proprietary nature of swf and flash it is difficult to add support for these formats to vMix. I recommend you use a flash video converter to convert these files into a more suitable format such as MPEG2. One such program is the Prism Video Converter: http://www.nchsoftware.com/prism/Regards, Martin
Converting them into MPEG2 will render my live text inexistant...
What I would like to accomplish is having a way to add live text from a DB (using mask). I don't mind loading an other format you would recommend but it needs to be able to be updated live...:)...
Keep up the good work, cheers...
I've been able to get SWF into vMix using the Flash player for Internet Explorer. So this feature should appear in the next version...
