Derrick
#1 Posted : Tuesday, December 6, 2022 6:00:52 PM(UTC)
Derrick
South Africa
I had a power failure during a live stream resulting in a very very large mp4 file that could not be played.
I found https://restore.media, somewhere deep in a discussion on this forum (so thank you to to you!).
The way it works is that you upload the damaged recording and a sample file at the same settings to their site.
They then do a scan of the file and generate a preview for you to check. If you are happy with the preview - you pay and download. $41 for a 90minute file was 'cheap at the price'.
The file was full quality with audio in sync.
Tried a bunch of other solutions which cost a lot more (and which did not work).
Restore.Media actually has a vMix 'profile' - which is why I think it works.
Going to take the rest of the day off to recover from the stress of having 'lost' that file.
Hope this helps someone...
Derrick
melody
#2 Posted : Tuesday, December 6, 2022 9:53:15 PM(UTC)
Rank: Guest
Groups: Guests
hi,
after a little search on google, i founded some free software that can do the same as describbed above...
https://listoffreeware.c...ir-software-for-windows/
hope this helps also... have a great week
melody
Joeboe
#3 Posted : Wednesday, December 7, 2022 1:10:33 AM(UTC)
Joeboe
Als, record with Fault Tollerence
