GT
sideways moving graphics
Joined: 9/21/2021(UTC) Posts: 9  Location: Elektrėnai Was thanked: 1 time(s) in 1 post(s)
Hello, Maybe someone has an idea how to make the new graphics that appear to move to the side with all the texts? ExampleI have imagesequence all the graphics, but don't know how better to use it. Also what is the best way to use a .gtzip graphic so that it has animations? Overlay is not suitable because there can only be 4 of them, I may need 8 at the same time. LAYERS/Multiview would be fine, but doesn't trigger the animation. Perhaps it is possible to make the animation transition in when the layer is turned on, and transitionout when it is turned off? Page in GT Designer is not the option, because when I click transitionout, I no need that out goes all pages, but its happen.
Originally Posted by: titasas  Hello, Maybe someone has an idea how to make the new graphics that appear to move to the side with all the texts? ExampleI have imagesequence all the graphics, but don't know how better to use it. Also what is the best way to use a .gtzip graphic so that it has animations? Overlay is not suitable because there can only be 4 of them, I may need 8 at the same time. LAYERS/Multiview would be fine, but doesn't trigger the animation. Perhaps it is possible to make the animation transition in when the layer is turned on, and transitionout when it is turned off? Page in GT Designer is not the option, because when I click transitionout, I no need that out goes all pages, but its happen. Short of external graphics software imo best bet is to use legacy XAML (WPF) title with some codebehind where animations can be triggered using the values/conditions (criteria dependent) .WOuld be very tricky to do with GT if at all Here is an example of trigering an animation based on text content:
GT
