Owallen
#1 Posted : Friday, November 18, 2022 1:33:17 AM(UTC)
Owallen
Sweden
Our main problem isn't to few SDI outputs but the fact that the outputs are shared with streaming and recording.
Yes, I know it's possible to choose between outup 1-4 for recording but only 1-2 for streaming.
Also, I miss thiss setting to be reflected under "Description" in the "Output/NDI/SRT/ panel.
Output 1 will show "Record / Stream / External" even if I've set Record to output 3 or Stream to output 2.
Ideally I would like to be able to set as an example Streaming and recording to Output 3 and/or Output 4 in order to choose what ever I want to send to the SDI outputs on External 1 and 2.
And also see this reflected in the settings panel.
RichShumaker
#2 Posted : Friday, November 18, 2022 4:39:26 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
I seem to remember there is a "Technical Windows" issue that can not be overcome.
Of course I am not the expert just typing what my bad memory remembers.
Owallen
#3 Posted : Saturday, November 19, 2022 1:45:19 AM(UTC)
Owallen
Sweden
As all Outputs can stream both SRT and/or NDI it would make sence that it also should be possible to stream RTMP on either of the 4 Outputs. If not, it would be interesting to know why.
joedemax
#4 Posted : Friday, November 25, 2022 1:55:13 AM(UTC)
joedemax
Was thanked: 10 time(s) in 6 post(s)
Just a suggestion - You could use Nimble on something as inexpensive as a Raspberry Pi to flip SRT to RTMP. It requires very little CPU power because it just rewraps the stream - no re encoding.
I did the other way round last year to get SRT output from an ATEM Mini. Works great.
https://www.youtube.com/watch?v=5sSJkIuvTP8
thanks 1 user thanked joedemax for this useful post.
Owallen on 11/25/2022(UTC)
Owallen
#5 Posted : Friday, November 25, 2022 2:31:37 AM(UTC)
Owallen
Sweden
Thanks for the suggestion!
It would offcourse be more convenient to avoid extra hardware to reach the goal but I will definitely check it out as it may be a temporary solution.
