Joined: 11/22/2018(UTC) Views messages in topic : 12  Location: Malmö Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Our main problem isn't to few SDI outputs but the fact that the outputs are shared with streaming and recording. Yes, I know it's possible to choose between outup 1-4 for recording but only 1-2 for streaming. Also, I miss thiss setting to be reflected under "Description" in the "Output/NDI/SRT/ panel. Output 1 will show "Record / Stream / External" even if I've set Record to output 3 or Stream to output 2.
Ideally I would like to be able to set as an example Streaming and recording to Output 3 and/or Output 4 in order to choose what ever I want to send to the SDI outputs on External 1 and 2. And also see this reflected in the settings panel.
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
I seem to remember there is a "Technical Windows" issue that can not be overcome.
Of course I am not the expert just typing what my bad memory remembers.
Originally Posted by: RichShumaker  I seem to remember there is a "Technical Windows" issue that can not be overcome.
Of course I am not the expert just typing what my bad memory remembers. As all Outputs can stream both SRT and/or NDI it would make sence that it also should be possible to stream RTMP on either of the 4 Outputs. If not, it would be interesting to know why.
Joined: 6/23/2017(UTC) Posts: 29  Was thanked: 10 time(s) in 6 post(s)
Just a suggestion - You could use Nimble on something as inexpensive as a Raspberry Pi to flip SRT to RTMP. It requires very little CPU power because it just rewraps the stream - no re encoding. I did the other way round last year to get SRT output from an ATEM Mini. Works great. https://www.youtube.com/watch?v=5sSJkIuvTP8
 1 user thanked joedemax for this useful post.
Originally Posted by: joedemax  Just a suggestion - You could use Nimble on something as inexpensive as a Raspberry Pi to flip SRT to RTMP. It requires very little CPU power because it just rewraps the stream - no re encoding. I did the other way round last year to get SRT output from an ATEM Mini. Works great. https://www.youtube.com/watch?v=5sSJkIuvTP8 Thanks for the suggestion! It would offcourse be more convenient to avoid extra hardware to reach the goal but I will definitely check it out as it may be a temporary solution.
