Originally Posted by: Zetor1980  Overlay 4 is not working, settings are the same as in 1,2,3. Those are good. Preview, when started with right mouse key, works fine. vMix 25.0.0.34 Need more details ( working just fine here) How is your preview right click related to overlay 4? What type of input are you using to overlay 4? What are the overlays allowed in output settings ? What exactly do you mean by not working ?
Originally Posted by: Zetor1980  Any input, but for instance, full screen color bars, when overlay 4 under the icon of this bars is clicked with LMB - it's not on the output screen. When RMB clicked it's on preview screen. When 1,2, or 3 overlay is used everything is OK Settings of all are the same.
is this within a clean(new) preset?
Originally Posted by: Zetor1980  Originally Posted by: doggy  Originally Posted by: Zetor1980  Any input, but for instance, full screen color bars, when overlay 4 under the icon of this bars is clicked with LMB - it's not on the output screen. When RMB clicked it's on preview screen. When 1,2, or 3 overlay is used everything is OK Settings of all are the same.
is this within a clean(new) preset? Yes Sorry, only way i can simulate is having the ovl4 alpha setting to 0
Thanks: 74 times Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: doggy  Originally Posted by: Zetor1980  Originally Posted by: doggy  Originally Posted by: Zetor1980  Any input, but for instance, full screen color bars, when overlay 4 under the icon of this bars is clicked with LMB - it's not on the output screen. When RMB clicked it's on preview screen. When 1,2, or 3 overlay is used everything is OK Settings of all are the same.
is this within a clean(new) preset? Yes Sorry, only way i can simulate is having the ovl4 alpha setting to 0 Solved, in Display options it was disabled. Thank, You doggy :)
