Toldorn
#1 Posted : Tuesday, April 27, 2021 10:31:24 AM(UTC)
Toldorn
Hi there,
I've been filming live sports and usually use a Netgear Nighthawk over Ethernet (on the Telstra (Australian telco) 4g network). However, the last few weeks it's been unreliable and cutting out up to 2/3 times a half!
I've lowered the bandwidth as low as I can afford (down to 720 2.5mpbs) and it's still not 100% reliable.
So, I'm looking at a solution where I plug my mobile phone (which is on the Optus 4g network) in over USB and tether that to my device as a 'backup' internet connection.
Can anyone tell me if this is possible to have two connections on the 1 laptop, so if one dies, the stream will carry on?
Thanks!
Hill265
#2 Posted : Tuesday, April 27, 2021 2:06:05 PM(UTC)
Hill265
Odds are, you have a backup internet connection in your pocket. On your phone or 4G/LTE equipped tablet, you already have an internet connection that's To enable it, open Settings, select the Personal Hotspot option near the a USB cellular dongle or want to share your wired Ethernet connection.
NJMCDirect
Toldorn
#3 Posted : Wednesday, April 28, 2021 8:32:17 AM(UTC)
Toldorn
Hi there. Yes, I have both my phone (usb) tethered, and nighthawk connected - windows shows me 2 connections in the task-bar - but when I disconnect one, the stream dies. It doesn't automatically use the other connection.
any ideas?
Vince Beck
#4 Posted : Wednesday, April 28, 2021 10:54:36 AM(UTC)
Vince Beck
Is there a third adapter in there that might be higher in the priority order?
https://www.windowscentr...work-adapters-windows-10
matkeane
#5 Posted : Wednesday, April 28, 2021 10:26:36 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
I'm not an expert on networking by any means, so I don't know whether Windows is capable of maintaining a connection when switching between adapters. For a redundant setup, I think you need to look in to 'connection bonding' which some routers support. That way you can connect the router to a fibre connection and a 4G connection and let the router handle the failover from one to the other. I've done a crash-test of this at work - unplugging the fibre cable in the middle of a vMix call - and the incoming call & outgoing stream connections weren't dropped.
mctober
#6 Posted : Friday, April 30, 2021 6:51:58 AM(UTC)
mctober
Netherlands
I use Speedify to combine multiple connections, you can select priority's, and have an eye on the amount of data. Worked for me so far!
rss
#7 Posted : Saturday, November 19, 2022 5:19:48 AM(UTC)
rss
Romania
You use Speedify with vmix calls?
Do you have delays on connections? I use at least 6 vmix calls in my Q&A and I'm curios how works with Speedify... !?
Pavel
#8 Posted : Saturday, November 19, 2022 6:04:58 AM(UTC)
Pavel
I use Speedify with 2-3 LTE USB modems and 100% reliability.
rss
#9 Posted : Saturday, November 19, 2022 7:38:24 AM(UTC)
rss
Romania
Good to know for vmix calls if works fine with Speedify. I was worry about delay.
Thank you, Pavel!
Guest (10)
